jjdinks
3 years agoFriendly Neighbour
- 3 years ago
jjdinks
No, I could probably find some videos online or just use the existing DSL run to the T3200 and use that to fish the new ethernet cable in.
As for my home phone, I am pretty sure it is not on fiber so its not being connected from the ONT. I believe this is true because on the MyTelus website I am offered the option to switch the home line to fiber.
Anonymous
3 years agoYour home phone line is on a separate line, on the existing copper line.
The ethernet is on a separate line, then a ethernet cable run between the ont modem and the adsl, ethernet adapter.
- xray3 years agoHeroYes, the cheapest solution is to run an Ethernet cable from the ONT to the T3200M WAN port. If logistics are too complicated for doing that (walls and floors) then next cheapest option is Nighthawk suggestion of using MoCA adapters if you have an existing coax (cable) run. Third choice is PowerLine adapters that use the house power wiring.
- jjdinks3 years agoFriendly Neighbourso ethernet cable from ONT to T3200 right so that I get Gigabit from the T3200?
No adapters needed right?
And to once again confirm, I will need to make this cable run myself?
