jjdinks
3 years agoFriendly Neighbour
- 3 years ago
Anonymous
3 years agoYou would probably need a separate phone line from the ont modem which has a RJ11 phone jack for the phone line which telus technicians from the fibre team can help with re connecting between the T3200 m and the ont modem
Also a separate line for ethernet on data 1 or lan 1 from the ont modem to the T3200 modem which you can install yourself or you would have to ask a it company or pc or network repair technicians that install network wiring or structural cabling of ethernet , coaxial or phone lines.
3 years agoAnonymous No, you are incorrect. Phone service, if they have a landline, would be wired to the ONT, not the T3200. There is never any case where an RJ11 cable is connected between the ONT and the T3200.
You are also incorrect in recommending an IT company, a PC repair company, or a "network repair technician" (which isn't a real thing). None of them, for the ones that exist, would be re-wiring a residence. The only correct answer is to contact Telus and have a tech sent out to ensure a proper connection is in place between the ONT and the T3200.
