EBAL
1 year agoOrganizer
T3200M as replacement for separate MOCA adapter and switch combo
Hi all, I'm currently using a MOCA adapter and switch combo in a secondary room to connect to my ASUS router in the main room via coax cabling. I would like to connect a third room to the same ...
1 year agoThe T3200 is not designed to work like that. You will run into problems if you tried. If you wanted devices to be on the network created by the Asus router, you'll need to connect the devices / switch to the Asus by ethernet.
