magg992001
6 years agoNeighbour
Smart Hub is limited wifi.
The Smart Hubs are limited to wifi connections. I have a ZTE MF279T and am always struggling with having to shut off connected devices, cameras, kids devices etc. etc. Is there something I can do t...
k2spirit839
5 years agoCoach
The zte mf279t smarthub is a duel band wifi router. So it has 2.4GHz wifi band and 5GHz wifi band. Either band can handle 10 wifi devices. So the 2.4GHz wifi band has 10 wifi devices and the 5GHz wifi band has 10 wifi devices. So the hub can handle 20 wifi devices at any given time.
RonAKA
5 years agoRockstar
If you can separate the two bands and set up two independent WiFi networks, one for 5G and one for 2.4G, you will have more control. The 2.4G band has more range than the 5G. You could sign on the more distant (weaker signal) devices to the 2.4 G.
- adamthebad5 years agoAdvisorGreetingsfollowup...by turning the telus 279 rural hub into a gateway and not use it as the modem actully increases speeds slightly as I can remotely control/check cameras/devices quicker.5G signals across ten acres (almost 436000sq.ft.) requires way to many upgrades as with 2.4G which is way more cost effective.As for a urban setting which i also have the telus unit is also just a gateway as well because of the Minimal setup to get by for the price paid....so again a external performer is attached to provide a wider faster gain in performanceOn Oct. 14, 2020, at 10:00 a.m., TELUS Neighbourhood < telusneighbourhood > wrote:
Hi adamthebad,
RonAKA (Ambassador) posted a new reply in Internet & Home Phone on 10-14-2020 10:00 AM:
Re: Smart Hub is limited wifi.If you can separate the two bands and set up two independent WiFi networks, one for 5G and one for 2.4G, you will have more control. The 2.4G band has more range than the 5G. You could sign on the more distant (weaker signal) devices to the 2.4 G.
You are receiving this email because a new message matches your subscription to a topic.
To control which emails we send you please go to, manage your subscription & notification settings or unsubscribe.
