JonoSK's avatar
JonoSK
3 years ago
Solved
Smart device and 2.4 GHZ
Another question about connecting smart devices requiring a 2.4 GHZ connection.
Background
- I have several smart devices (Meross smart bulbs, HomePod, Chromecast audio, Google Nest Mini) already hooked up to my WiFi.
- WiFi was previously using Smart Steering and I had no issues with setup/accessing/controlling my devices
Now
- I have a new smart device (Meross Smart Plug with Matter. model: MSS115) that was a huge pain to connect to the WiFi. In trouble shooting I learned about Smart Steering (new to me) and disabled it. This finally allowed me to connect the Meross plug. I also made sure the 2.4 GHZ SSID was the same name as my normal SSID so that WiFi name/password would be the same. Even if my phone is on the 5 GHZ WiFi, I can control the Meross Smart Plug.
- I thought I could re-enable Smart Steering once I had connected the Meross Smart Plug (same SSID/password). But it turns out, every time I re-enable Smart Steering, my Meross Smart Plug is not accessible. All my other devices still are. When I check in the Network Device Table, it appears the plug is connected to 2.4 GHZ
Question
- Why won't it work when Smart Steering is on?
- What solutions can you suggest to allow it to still be controlled with Smart Steering on?
  • Smart Steering is convenient for the initial install where the SSID and password are set to what the sticker on the router says. This way it should work right away for any device without the user needing to know the WiFi capabilities of their device and being confused by separate SSIDs for each band that have cryptic names. It is highly recommended that users change the SSID and password anyway for security reasons so Smart Steering has little value after that.
  • Could be channel congestion. Try selecting a different channel for the 2.4 GHz band.
    • HiTop's avatar
      HiTop
      Turns out my modem was defective... telus replaced it an now everything is working...
      • dru's avatar
        dru
        Thanks for sharing your resolution, HiTop!
  • JonoSK wrote:
    Question
    There really isn't any benefit in having Smart Steering on. Using separate SSIDs for each band is easy to manage and connections are more reliable. I've never used Smart Steering and I have no issues connecting the 48 devices on my network.
    • JonoSK's avatar
      JonoSK
      That is helpful! I was under the impression Smart Steering was a benefit so I was trying to find a way to make it work. But if it doesn’t offer a huge advantage, then I guess what I’ve done is working
  • Nighthawk's avatar
    Smart Steering will switch between 2.4 and 5GHz without warning. I shut Smart Steering off years ago and have never had an issue since with any of my smart devices.
    • dru's avatar
      dru
      This was my approach also. Some of my smart home tech support 2.4 GHz only and the unfortunate reality is that you will need to relegate all your wireless products to run off that if you want it all to run smoothly. Caveat is that if you really need access to the theoretical higher speeds of 5GHz, that lone plug might throw a wrench into those plans.
      • HiTop's avatar
        HiTop
        Good to know... that would explain why my smart devices stopped connecting to my network. I've since shut off smart steering and then setup separate 2.4 GHZ connections... but they are so slow (1 - 13mb). So slow my 2.4 GHZ devices cannot connect... not sure why... is it a defective modem?
