JonoSK
3 years agoNeighbour
Smart device and 2.4 GHZ
Another question about connecting smart devices requiring a 2.4 GHZ connection. Background - I have several smart devices (Meross smart bulbs, HomePod, Chromecast audio, Google Nest Mini) alread...
- 3 years ago
Smart Steering is convenient for the initial install where the SSID and password are set to what the sticker on the router says. This way it should work right away for any device without the user needing to know the WiFi capabilities of their device and being confused by separate SSIDs for each band that have cryptic names. It is highly recommended that users change the SSID and password anyway for security reasons so Smart Steering has little value after that.
3 years agoHero
JonoSK wrote:Question
- Why won't it work when Smart Steering is on?
- What solutions can you suggest to allow it to still be controlled with Smart Steering on?
There really isn't any benefit in having Smart Steering on. Using separate SSIDs for each band is easy to manage and connections are more reliable. I've never used Smart Steering and I have no issues connecting the 48 devices on my network.
- JonoSK3 years agoNeighbourThat is helpful! I was under the impression Smart Steering was a benefit so I was trying to find a way to make it work. But if it doesn’t offer a huge advantage, then I guess what I’ve done is working
