JonoSK
3 years agoNeighbour
Smart device and 2.4 GHZ
Another question about connecting smart devices requiring a 2.4 GHZ connection. Background - I have several smart devices (Meross smart bulbs, HomePod, Chromecast audio, Google Nest Mini) alread...
- 3 years ago
Smart Steering is convenient for the initial install where the SSID and password are set to what the sticker on the router says. This way it should work right away for any device without the user needing to know the WiFi capabilities of their device and being confused by separate SSIDs for each band that have cryptic names. It is highly recommended that users change the SSID and password anyway for security reasons so Smart Steering has little value after that.
dru
Community Manager
3 years agoThis was my approach also. Some of my smart home tech support 2.4 GHz only and the unfortunate reality is that you will need to relegate all your wireless products to run off that if you want it all to run smoothly. Caveat is that if you really need access to the theoretical higher speeds of 5GHz, that lone plug might throw a wrench into those plans.
HiTop
Good to know... that would explain why my smart devices stopped connecting to my network. I've since shut off smart steering and then setup separate 2.4 GHZ connections... but they are so slow (1 - 13mb). So slow my 2.4 GHZ devices cannot connect... not sure why... is it a defective modem?
