X000748
4 years agoNeighbour
Rotating public IP after setting bridge mode
I have a Telus modem/router and my own one. I have recently set bridge mode on on the Telus router. After that I 1) cannot connect back to my Telus router and 2) my public IP keeps rotating almost eve...
DrPacman
4 years agoRockstar
X000748 Wrote: I have recently set bridge mode on on the Telus router.
Specifically which Telus router are you utilizing? Cheers...
X000748
T3200M
- DrPacman4 years agoRockstar
X000748 Wrote: T3200M
Give this a quick try...
Plug a computer into port 4 of the T3200M and see if you get internet. If you do you should be able to get to the modems GUI interface using the standard 192.168.1.254 IP.
If you can't get any activity, you might just have to factory reset the T3200M and start all over again.
The following link should take to to the online pdf manual for the T3200M, most of the configuration setting should be included in it... Cheers...
https://www.192-168-1-1-ip.co/manuals/9077.pdf
