Serpentor
9 months agoNeighbour
This isn't really a question, it's just FYI for Ontario (and, I assume, Quebec) customers that have Telus Pure Fibre, delivered on Bell's fibre. In Ontario, Telus has to use PPPoE. Make sure you...
Mreid153
8 months agoNeighbour
I have had zero luck bridging my NH20A to my Flight 2 router. Can't connect by DHCP or PPoE.
I exposed the password field and have my PPoE PW (6 digits?).
Was unable to bridge on either Lan 1 or 10g
- Serpentor8 months agoNeighbour
Does your router have logs for the PPPoE authentication? If you're in Ontario (Bell last mile), they use PPPoE. I set my NH20A to bridge all interfaces.
From what I've read, some people have had to factory reset the NH20A then put it in bridge mode for it to work.
- supermario4 months agoNeighbour
Bell is using straightforward PPPOE PAP based authentication with no fuss from years ago. This works well and works off any of their modem ports. Their Advanced DMZ mode is known to fail as it's internal NAT routing is flawed and not reliable if it works at all. Only their business modems work properly in this regard. On the residential side, they don't want you to use your own routers.
- Mreid1538 months agoNeighbour
I'm in Ontario,
Did multiple factory reset, tried 10g port, LAN1 with no luck
PPoE and DHCP.
I'll tinker a bit more and get the logs when I get some time, but I'm not sure if there is anything on Telus end that has to be done first. When I spoke to tech support they said it should be working.
I appreciate your response, thank you
see my post from today. There is further config required and you will need to create a VLAN with tag 35 in your own router.
Flint 2*
