Rubato
6 years agoHelpful Neighbour
Structured cabling for fibre and home phone
Hello. I’m doing a full basement reno in our 70 year old house, so all the walls and ceilings are open for excellent access for wiring. We plan to install ethernet cabling and phone lines to seve...
- 6 years ago
I recommend at least 2 runs of Cat5 to each location in your home, and 3 to TV locations. Phone is easily managed with cordless handsets, and one central base station, but internet is best served by wired connections. Use standard Ethernet B wiring diagrams.
6 years agoThe telephone output of the ONT was simply connected to the existing copper phone wires (4 conductor) in my house. The Tech simply disconnected the incoming copper phone line at the demarcation point, and connected the ONT output instead. It took longer to reprogram the line from copper to Fibre than to make the connection.
Rubato
Interesting! I'll start strategizing my wiring plan with simple parallel connections in mind. Any thoughts about the quality of the cable I should run to the room jacks, perhaps with any kind of future-proofing to consider? Are there any standards that I would be wise to adhere to. In old houses that I've added phone line locations to, the red and green wires in the 4 wire solid copper cable were the relevant ones. The Telus tech who did our temporary installation ran cat5e cable from the J-box that connects with POTS1 of the ONT to the main floor phone jack, and used the blue and white wires of the cat5e.
Thanks again for your help. It's so nice to to have this resource, and I thank Telus for hosting this forum.
- NFtoBC6 years ago
- Rubato6 years agoHelpful Neighbour
Hi NFtoBC,
Thanks for your advice on this. Although we don't have (or want) TV, I'll consider running cable for it to 2 or 3 locations for future owners of this house. Have to see how the budget is!
