Rocky3
2 months agoGuardian
SOUND
I am watching a show, whether live TV, recorded or streaming. The sound volume goes up and down during the show. At times (TV sound 1-100) it will be just right at 10, other times it is 50. This is ...
15 days agoRocky3 Grimmt An update: our team is aware of the issue and we're working on a fix. When there's more info we can share, we will definitely let you know.
KHR
TELUS Team Member
15 days agoCan you help us out with some details a bit to try and get to the bottom of it?
- can you confirm set-top box make/model (TELUSTV-21T or TELUSTV-24S, other)?
- is it across all channels?
- do you have your set-top box volume set to 15 (ask google assistant to 'set volume to max')?
- Are you using anything other than set-top box to tv and using TV speakers?
- Any sound settings you've changed on your TV?
- Grimmt15 days agoAmbassador
Here’s my info:
TELUSTV-21T
Yes
Interesting: I did this on one of my TVs and the volume instantly increased and I needed to reduce the TV volume. I’ll monitor if the problem continues.
Meanwhile: Is there a way to query what the current setting is before doing this? I would assume this would be important feedback. I have not done this on my other TV; so, I can provide info from my other TV that has the same issue.
No – I have the TELUSTV-21T directly connected via hdmi
Before the problem started? no
Since the problem started? yes – many changes in an unsuccessful attempt to fix the problem.Tony
And a question and answer, surprisingly missing from the questions - maybe the set top box reports this:
What make and model of TV do you have?
LG OLED CX- KHR15 days ago
TELUS Team Member
Thanks for the detail; you'd mentioned earlier that you have a Sony and a LG, so I didn't feel the need to re-ask 😁. The fact you see it on different TVs from different manufacturers from different years running different operating systems (and so Rocky sees it to) indicates it's something on our end or the broadcasters end. You can ask google assistant what volume you're set to (i think my exact prompt was "what's my volume set to?").
