MariuszStepien
4 years agoNeighbour
I upgraded to PureFibre 1.5 GB but speed remains 1GB
It is a simple set up, one hard wired computer and Cat6 cable. Telus support not very helpful. I'm confused - did all the restarts etc... Any suggestions ?
- 4 years ago
MariuszStepien Wrote: which should support connection up to 10GB
No sorry, it only supports a 1Gbps connection... Cheers...
DrPacman
4 years agoRockstar
MariuszStepien
That's helpful thank you.
