wudao2001
5 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
rcruz
4 years agoFriendly Neighbour
Same problem here. I do not have the LAN menu on my IP gateway settings therefore I still am not able to connect my redlink to the internet and it is still on Amber. Talked to multiple Telus tech agents and they can't seem to find the issue nor understand what is going on.
Pruthvi077
3 years agoNeighbour
Hi, just use TP Link network switch, attach with your router or anywhere the Ethernet cable available, and then Redlink attached to TP Link the it should work.
Mine is working that way.
