wudao2001
5 years agoNeighbour
- 4 years ago
- Logout
- THANKS ANNA!!!
rcruz
4 years agoFriendly Neighbour
Yeah I'm wondering how Dnice40 was able to access the other IP gateway if they had the Wi-Fi Boost 6. Would be nice to know how to do it and be done with this issue once and for all.
RinSoCal
4 years agoOrganizer
This is oddly unexpected, but I'll take it:
- Up to November 6 - ~6 offline messages in my inbox daily
- November 7 to now - NO offline instances
How are things on your end?
- rcruz4 years agoFriendly NeighbourHopefully they will provide a proper fix on all their routers/boosters/modem because I spoke with 2-3 agents and they don't seem to know or understand what the issue is and how to fix it. I even offered to give them the link to this thread to help them better understand the situation but refused to do so.
- paulpooco4 years agoOrganizer
I work for TELUS and reported the issue to an article they had at work about compatibility of the different Gateways and different TELUS hardware about 2 week ago or so.
- rcruz4 years agoFriendly NeighbourI didn't realize you have a different router than I do. I have the Wi-fi 6 booster, the white cylindrical router/booster. Mine still doesnt work though.
