Jaybor
3 years agoNeighbour
Port Forwarding Issue
I want to host a server on teamspeak3, but this requires some port forwarding to work.
The below site link says they're not open when I tested.
https://www.portcheckers.com/
EDI...
- 3 years ago
Jaybor Wrote: I hope Telus isn't simply blocking all port forwarding.
No Telus is not blocking all port forwarding, however, they do block some ports on residential internet connections. See this thread for more info.
Delzers
I am having a similar problem. I run a MC server, and I had everything working. I recently had an "upgrade" to wifi boost with a new router and now only some can connect to my server. So far only other Telus customers and Mobile connections can reach the server (tested as telus and Freedom mobile hotspotting). But Shaw residential accounts cannot. First level tech support was able to help. But if they are blocking ports, they are also blocking ip's. Very frustrating. I have another server that runs on the Steam platform and that one has no problem. Both are running off the same hardware so I know it's not my settings.
Delzers
Addendum, Telus first level support WASN'T able to help.
