Jaybor
3 years agoNeighbour
Port Forwarding Issue
I want to host a server on teamspeak3, but this requires some port forwarding to work.
The below site link says they're not open when I tested.
https://www.portcheckers.com/
EDI...
- 3 years ago
Jaybor Wrote: I hope Telus isn't simply blocking all port forwarding.
No Telus is not blocking all port forwarding, however, they do block some ports on residential internet connections. See this thread for more info.
3 years agoHero
You haven't given any details about how you set up your forwarding so it's hard to say why it's not working.
Are you testing the port with telnet from inside or outside your home network?
