Jaybor
3 years agoNeighbour
Port Forwarding Issue
I want to host a server on teamspeak3, but this requires some port forwarding to work.
The below site link says they're not open when I tested.
https://www.portcheckers.com/
EDI...
- 3 years ago
Jaybor Wrote: I hope Telus isn't simply blocking all port forwarding.
No Telus is not blocking all port forwarding, however, they do block some ports on residential internet connections. See this thread for more info.
FuzzyLogic
3 years agoFrom what I've seen Teamspeak3 doesn't use any ports that would be blocked by Telus.
Assuming you have an T3200M this article may be helpful in configuring port forwarding:
Opening Ports in a Actiontec T3200M Router (portforward.com)
