ewantaylo
4 years agoNeighbour
No connection to anything other than google sites over LAN, but a full connection over wifi- except!
This is for a telus wifi hub router/ modem combo. My wifi works, but my LAN doesn't. Wifi will load anything I want, but a wired connection will only load google services. I've tried with two laptop...
- 4 years ago
Have you played with any setting in the router? If so what? This was from yesterday, has it resolved itself?
What's the model # of the wifi hub router/ modem combo? what is the physical signal path/chain of your present equipment?
Reboot
Factory reset
Physical wiring changes
LAN DHCP static addressing, range setting
MAC address filtering allow/denial list
IP conflicts
etc
ewantaylo
I've had this issue since I got telus internet in mid january. I've reset and factory restored it the router multiple times.
This is all my router info.
Present path is- ethernet line into the wall, and then a cable from the wall port to my PC. I've tried a few cables, and even plugging directly to the router.
I'll try adding my MAC to a whitelist and setting a static address.
The devices connected to the ethernet cables are definietly connected to the internet though- it's just that they can only go to default google sites.
kamak
4 years agoAmbassador
Also an easy thing to do. Spoof your MAC address. But you did say ALL computers on ethernet can only get to Google services, and not surf the net? What do you mean google services, and not actually surf any internet? That definitely sounds like DNS issues. Try creating a new DNS with your IPv4 properties. I use a lot, 1.1.1.1 / 1.0.0.1 or 8.8.8.8 / .... or if you are already using your own selection try going back to default and use Telus' DNS services.
