ewantaylo
4 years agoNeighbour
No connection to anything other than google sites over LAN, but a full connection over wifi- except!
This is for a telus wifi hub router/ modem combo. My wifi works, but my LAN doesn't. Wifi will load anything I want, but a wired connection will only load google services. I've tried with two laptop...
- 4 years ago
Have you played with any setting in the router? If so what? This was from yesterday, has it resolved itself?
What's the model # of the wifi hub router/ modem combo? what is the physical signal path/chain of your present equipment?
Reboot
Factory reset
Physical wiring changes
LAN DHCP static addressing, range setting
MAC address filtering allow/denial list
IP conflicts
etc
4 years agoHero
Just to clarify what you are saying, when you say LAN do you really mean Ethernet? LAN (Local Area Network) is the private network behind your router. It doesn't matter how the devices are connected (WiFi or Ethernet) they are on the LAN.
Assuming you mean Ethernet, are you testing with the same devices for WiFi or different devices? It might be a DNS setting issue on the devices.
ewantaylo
I do in fact mean ethernet. I've tried the same devices on both wifi and over ethernet. I've tried both wifi and ethernet on most of the devices (Don't have an adapter for the xbox.)
- kamak4 years agoAmbassador
Reboot
Factory reset
IP conflicts
etc
- ewantaylo4 years agoNeighbour
I've had this issue since I got telus internet in mid january. I've reset and factory restored it the router multiple times.
This is all my router info.
Present path is- ethernet line into the wall, and then a cable from the wall port to my PC. I've tried a few cables, and even plugging directly to the router.
I'll try adding my MAC to a whitelist and setting a static address.
The devices connected to the ethernet cables are definietly connected to the internet though- it's just that they can only go to default google sites.
If I'm reading this correctly you're getting "FULL" internet connectivity, but not LAN connectivity when using ethernet?
"No connection to anything other than google sites over LAN"
