Powderjockey's avatar
Powderjockey
Advocate
10 months ago
Need Remote Code ofr Amazon FireTV
I received a replacement remote, Slimline2, and would like to find the code to set up the TV on the Slimline2. The model of the TV is a QL43F601C. I followed the enclosed instructions that came with the remote and of course there is no Amazon Fire TV list. So I tried using the 0029 code and held the power button for 17 minutes and the TV never turned off. I've search the internet, watched a tone of Youtube videos, all really having nothing really to do with the code required for the Amazon FireTV and the Telus Optik remotes. The old remote which was a Slimline1 did work with the TV.
Does anyone by chance know where to find the code or have it?
Appreciate any and all help.
  • Thanks for your reply. I gave the code 10154 a try,  but no success.
    I had already tried the 0029 and held the power button for 17 minutes and nothing happened, as stated in the OP. The LED flashed numerous times and then stopped.
    When pressing the TV power button, the LED does nothing.
    • TELUS_Support's avatar
      On your TV, can you go to Settings > Display & Sounds > HDMI CEC Device Control? We found online that a user posted that guide and if you switch it off the 4-digit code will appear but without the manufacturer it's hard to say which code will work.
      Let us know and if it is still not working we'll try to get insight from our support team
      • Powderjockey's avatar
        Powderjockey
        Advocate
        Thanks again for the reply, I had also found this post on the internet, it also did not show any codes when attempting to reveal. My device has Display & Audio>HDMI-CEC Device Control>One Touch Play or ARC/eARC or Power Control or Remote Control Pass-Through. All are enabled. Turn off showed no code and then turning back on showed nothing. Amazon may have shut that down.
    Hi! For your TELUS Slimline 2 remote and QL43F601C TV, try code 10154, use the Auto-Search method (holding Options, then entering '29' or '0029' and waiting up to 15 mins for the TV to turn off/on), or look for the TV in the on-screen menu if available, as the older Slimline 1 remote working suggests compatibility exists, but codes can vary with the newer remote version.
