Juicebox
1 year agoNeighbour
Modem/Router settings Causing issues with VOIP
So i have the following products NH20A - modem The white cylinder for the WIFI booster. I have been trying to find a setting where I can disable my "SIP ALG" (Application Layer Gateway). Ty...
maskedmark
7 months agoNeighbour
Hello. I'm planning to run a third-party VOIP service off the NH20A modem and I am requesting the "SIP ALG" feature be disabled as well. Is there anyone from Telus on this forum with the necessary "super admin" account to be able to do this? Please send me a DM and I'll provide my account number. Thanks!
7 months agoHello. We'll send you a private message, check your Inbox.
- Schmidt853 months agoNeighbour
Could you also message me i have the same SIP ALG issues and need it resolved
I cant access the message. The link says account verification error
- TELUS_Support3 months ago
We will send you a message as well Schmidt85
- Cooter3837 months agoNeighbour
Hi, I am also having the same issue. I need to Disable the SIPALG settings. I have a BoostLite BE74. I have been able to open UDP Ports 5060-5070, it worked for a couple of days but now it gives me an error code 3004 on my MajicJack
- TELUS_Support7 months ago
Thanks for reaching out. We understand the frustration when SIP ALG or port settings are causing issues with services like MagicJack. Unfortunately, we aren’t able to check or modify SIP ALG settings from here. To get this properly configured and resolve the error code 3004, please connect with our Technical Support team. You can reach them here: support.telus.com/home-expert-sm
- Cindos7 months agoNeighbour
Hi. I'm in the same situation with being unable to disable "SIP ALG". Are you able to help?
Hi Cindos - if you can send us a private message we can reach out to our Back Office team to disable the feature
