sherry9oct's avatar
sherry9oct
4 years ago
Solved
Max usb storage size that can be connected to Telus Wifi Hub USB white Arcadyan tower modem
I am using Telus Wifi Hub USB (white Arcadyan tower modem). I have connected 1tb HDD to the modem to create Nas. I wanted to confirm what's the max allowed size usb that I can connect. I am running ou...
  • NFtoBC's avatar
    4 years ago
    You should be able to add the maximum the format you are using allows. It should be many TB. Previous routers only allowed FAT32 format, and were quite limited in disk size.
