CAMERC
5 years agoOrganizer
Incoming Landline Phone Calls That Just Show "Incoming Call" on Call Display and Aren't Missed Calls
I occasionally receive an incoming call on my Panasonic landline that shows nothing in call display but "Incoming Call". I don't ever answer and the call eventually disappears without ever being subs...
- 5 years ago
Can you try the star code to find out the last number that called you and see what it says?
https://www.telus.com/en/on/support/article/use-star-commands#call_trace
Make sure not to use the call trace one unless you want it reported to the police.
CAMERC
Should mention I have a free Telus fax number associated with my phone as well...
- rc5 years agoRockstar
By "free fax number" do you mean you have a second, smart ring, number associated with your landline?
Do you have a fax machine sharing the landline?
If you call the fax number, does the Panasonic phone behave as you describe?
- CAMERC5 years agoOrganizerFirst question: Yes.2nd Question: a Brother (MFC-L2750DW) printer with fax capability connected to the phone.3rd question: no. The phone correctly registers the call as coming from a private caller (I used Google hangouts on my PC) and I see/hear the call answered and the resulting fax tone before hanging up.
- CAMERC5 years agoOrganizerFootnote... I'll have to see what the printer LED console is saying when the next such call comes in...
