MariuszStepien
3 years agoNeighbour
I upgraded to PureFibre 1.5 GB but speed remains 1GB
It is a simple set up, one hard wired computer and Cat6 cable. Telus support not very helpful. I'm confused - did all the restarts etc... Any suggestions ?
- 3 years ago
MariuszStepien Wrote: which should support connection up to 10GB
No sorry, it only supports a 1Gbps connection... Cheers...
MariuszStepien
My Ethernet - 10/100/1000BASE-T Gigabit Ethernet (RJ-45 connector) - which should support connection up to 10GB
DrPacman
3 years agoRockstar
- MariuszStepien3 years agoNeighbour
That's helpful thank you.
