HiddenValley
4 years agoOrganizer
Home theater remote programming for Telustv-21
Telus, PLEASE enable the NEW Android / Bluetooth Optick TV boxes (Telustv-21t) functionality to use 3rd party remotes. Not being able to use one of the most advanced AIO remotes "Harmony HUB" wi...
terowe
4 years agoFriendly Neighbour
I was able to use the Telus remote to train my Harmony Hub to know enough commands to use it quite well with the new Telus Android box from Technicolor. However, once you pair the remote to use Bluetooth (not IR) then it no longer appears to send IR codes. Anyway, with enough persistence and a bit of technical knowledge I was able to make it work
