Everlong
3 years agoFriendly Neighbour
Help running a web server on TELUS network IP issues, cant figure this out
Im running an Apache web server. Have my domain forwarded to my public IP. The server works as i can ping it and see it on my lan. I have forwarded and enabled communications on port 80 in the modem/...
FuzzyLogic
3 years agoAs far as I know Telus still blocks port 80 for incoming traffic on residential accounts. You would need a business account to use that port. I have a Synology NAS setup with web access but had to use alternate ports to make it work.
You will also need to do port forwarding on your router for the ports you assign to your web server. If you have a T3200M this may help:
Opening Ports in a Actiontec T3200M Router (portforward.com)
Related Content
- 8.1KViews19Comments
