Titanium
4 years agoOrganizer
Fibre drilling and termination box locations
Telus is installing underground fibre in my area, all the homes have underground utilities and all homes face the street head on. The homes all have from left to right (coming from the under ground...
kamak
4 years agoAmbassador
OK, there you go, You have existing conduit in the ground. Its just not the conduit you're used to thinking is conduit, it "Non ridged conduit" perfectly fine for Cat or Fiber. They will pull the fiber using the old Cat to the existing location on the side of your house, most likely not need to make any new holes in your siding. Done, solved. Let them do it. Just ask them to not make a new hole, they might have to enlarge it a bit but it'll be the same hole with the existing box or a slightly larger box.
Titanium
Nope. It's not soft conduit.
You can't slide stuff in and out of it. It's just Coax and Cat 5 that have been melted together under 1 rubber skin. There is zero clearance inside the cable.
- kamak4 years agoAmbassador
Oh, weird. Then they will have to pull/trench and possibly install conduit for the fiber, but it'll be in the exact same location and or replace what is there now.
