canadiansilver's avatar
2 days ago
Fiber installation: lawn trenching concerns
We live in Sylvan Lake and Telus is having a third party install fiber optic, the job is a pure GONG SHOW. Telus needs to get involved because they are not making friends. They cut through my lawn and I now have a trench that was only partially filled but also enough gravel on it near the road to start a gravel pit. My neighbors, they cut right through his irrigation so I need to check mine now, my sons house has some kind of connection box which is in the middle of the lawn about 10" in size, like why in the middle of the lawn, plus there is good chance they cut his irrigation also. These are the things I am aware of and I am sure with what I see it is just the tip of the iceberg.
In Arizona last year Google put in fiber where we have a home, they were quick and totally neat, the only thing you see is where they went down the road and then fully patched it. If Telus comes around asking to put fiber, my response now would be I need a $5,000 performance bond and then maybe they may actually do a good job.
  • Last year. I am not sure what you mean by "fully completed" but if that is when all of Sylvan is done it doesn't cut it. If it is after they complete doing each house it still doesn't cut it. Am I supposed to look after my lawn with gravel and a mess of dirt on it? Also why would they put some type of box in the middle of a lawn? It doesn't only not belong there but it nicely says "Telus" on it, not exactly good advertising.
    • TELUS_Support's avatar
      Typically, connections are put closest to the city ROW depending on where the underground cables were installed when the neighbourhood was built. What we can do is send you a private message, so you can share photos of the damage if you'd like. That'll give us something to take to our field team to check on. Check your Inbox, thanks.
    When did this trenching take place? We typically have teams that arrange for remediation after the work is fully completed.
