Swimmer1000
7 years agoNeighbour
Backup power for fibre access
I had fibre installed in my house and then had a power failure after that. When the fibre access was installed battery backup was not included. When the power failed the phone failed as well. Is powe...
7 years agoGenerally no longer included unless you do not have mobility services as well. The expectation is that in an emergency, you are more likely to use your cellphone, because it is closer at hand.
