RobG3987
2 years agoAmbassador
Audio receiver control
I've gone through the steps to successfully link my brand of audio receiver to the OPTV remote and the volume controls works fine. However when I press the power button on the remote (expecting all ...
RobG3987
The newest one that comes with the new OPTIK TV equipment. On the website it's called the "Telus TV Remote". The other 3 listed are Slimline 2, Slimline, and Classic which it is none of those.
craiger8
2 years agoHelpful Neighbour
Did you ever find a fix to this? My receiver also does not turn off but the TV and Cable box does when pressing the power button on the Telus remote. Volume was programmed the same way you did and works. My previous Shaw remote also turned on/off all 3 three things (TV, Receiver, Cable Box).
- RobG39872 years agoAmbassadorNope. Gave up trying to get Telus to help.
This system has sooooo many other problems that this was a minor inconvenience in comparison I just keep using my Shaw remote for the power on/off.- craiger82 years agoHelpful NeighbourAlright. Thanks for the quick reply though.
With Shaw I just needed the one remote and put away the rest. Now I have the Telus remote, receiver remote and my Apple TV box remote. TV remote is also nearby just in case.- RobG39872 years agoAmbassadorLol, yup,, same here. I wish this was the only problem. Much bigger ones. New ones every week.
