Buckala
2 years agoNeighbour
Audio issues when viewing 4K channels
I have a very odd issue with audio when viewing 4k channels. I noticed when viewing channels with my new wireless 4k Telus TV OPTIK box , the audio goes MUTE but will come back on when I change to an...
A-B
Community Manager
2 years agoHello. Just following up again as I've received some info from our Optik team, including some possible workarounds/troubleshooting. Here's a list of things you can try to see if they help:
- Update your screen resolution (720/1080); it can be then be swapped back afterwards.
- Update your aspect ratio to standard definition; it can then be swapped back afterwards.
- Check and/or reseat your HDMI cables to test.
- Try a different port on the TV itself (if available).
- Try rebooting your box while your TV is on.
- Try turning on the HDMI CEC setting (Settings --> General --> HDMI CEC settings --> Enable). Save and reboot.
- Try a sequential reboot of your STB/PVR (unplug power cord from your modem/router, then unplug power cord from your TV equipment, wait 15 seconds, and then reverse the order by plugging the TV equipment power cords back in, and then finally the modem/router).
- Try a new HDMI cable if you have one, or try an optic cable (some Denon receivers need an optic cable to work).
- Ds32 years agoNeighbour
I have a similar problem. No sound over tv speakers. A new problem as has worked before. All other channels work. Sound occurs for about one second as you change channels. Do the 4k channels have different sound settings.
thanks- Ds32 years agoNeighbour
Solved by going from Dolby to Stereo. Works for both
