Hogan
1 year agoOrganizer
Admin Login to Telus Wifi 6 Access Point & Device wont connect.
So I just got Pure Fibre. Its all hooked up & working well. But I have a problem that a couple of devices only can only connect to the 2.4 (or whatever) bandwidth. So my research has told me that sup...
Darren_P
1 year agoOrganizer
You need to login to the WiFi Booster, not the Fibre Hub.
The ip for mine is 192.168.1.15
The hub is 192.168.1.254
- Serge-E1 year agoHelpful Neighbour
Thank you for the hint.
In my case it was .42 for the WiFi6 router.
I used an App called who is on my network. I had my phone on the Telus SSID, nothing else connected to this SSID, aside from the 2x Boosters and my laptop. Easy to find the target IP to login.
- mirest1 year agoNeighbour
I was having the same issue and this did the trick for me, thank you! For those that are not aware, the Booster IP can be found in the Telus Connect App as well.
