Ingepenne
3 years agoNeighbour
Additional SSID on Telus arcadyan wifi hub?
So how do you another SSID to this modem? I cannot seem to find a way using the admin login 192….etc Is it possible? Or at the very least to secure the guest wifi option?
Ingepenne
Above is an example of a router capable of broadcasting multiple SSIDs.
The current setup of the telus unit is setup broadcast two SSIDs - the secure primary SSID and the unsecured Guest SSID ( for which you cannot assign a password)
Ingepenne
https://www.cisco.com/c/dam/en/us/support/docs/smb/routers/cisco-rv-series-small-business-routers/images/ab-multiple-20ssids-07132017-step-201.png
On my older telus modem/router I can easily to into admin and create a dedicated 5g ssid, a 2.4g specific ssid and a general or default mutliband ssid all with different names and passwords.
