winter1
3 years agoNeighbour
1.5GB speed help with telus router.
Hello I upgraded to the Telus 1.5G speed service. Setup. Garage has modem installed. Telephone wall jack in the second floor is connected by cat 8 to Telus cylinder router that shows 2.5gb. Tel...
- 3 years ago
Connect the switch to the Ethernet port in the wall, and attach the computer and the Wi-Fi 6 device to the switch.
winter1
As you mentioned earlier. If the name of it is the boost wifi 6 unit. How do I have it output 2.5gb on ethernet ports 1 or 2. Is there a new unit or a work around. Thanks.
3 years agoConnect the switch to the Ethernet port in the wall, and attach the computer and the Wi-Fi 6 device to the switch.
Related Content
I been paying for 1.5gbs speeds, but realized the smarthub they gave me is capped at 1gbs?
I been paying for 1.5gbs speeds, but realized the smarthub they gave me is capped at 1gbs? Just what the subject says. I'm in BC and my buddy also ran into this when he asked why he wasn't able to h...Solved337Views1Comment
