bpresber's avatar
bpresber
4 months ago
Voicemail Setting S22
Trying to set up my speed dial for Voicemail on my phone.
There are no options for adding a "Voicemail number" under Voicemail settings. The only 2 things under settings are "Service provider" which you cannot change and "Notification settings". There is no way to add a number. How do I set this up?
  • TELUS_Support's avatar
    bpresber The phone should automatically poll the settings during the activation process. Can you try rebooting the phone?
    Also, can you confirm whether FuzzyLogic's suggestion works? If not, we'll have to find you your voicemail server number.
  • FuzzyLogic's avatar
    FuzzyLogic
    I don't have that phone but I think this should work to get to your voicemail. Open the phone app, tap the keypad tab, and press and hold the 1 key.
