Signal strength
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
June
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
June
Hey @Wkmacd I would recommend an ethernet cable if that's possible.
- Eric
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
June
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
June
In the spirit of trying to help I will say that the point of it being wireless is for convenience and to be able to put the TV box in more places that are not accessible via ethernet.
Myself I love my Wi-Fi but when I want the lowest latency and highest reliability for when I am gaming I use an ethernet cable from my PC to my modem and they're about 2ft away.
You could get a booster for sure, but since it is also wireless you could run into a similar issue if the problem is a thick cement wall (for example).
In some newer houses all the wiring is done so you might just need to plug a cable into an ethernet port, plug it into the TV box and that's it.
- Eric
