August
Hi everyone,
We have moved into a new house, and were unable to migrate our Telus approved doorbell because the house is older and the doorbell is not able to be hardwired electrically.
I would like to install a battery powered device; Telus does not currently offer a device like that, but there are manufacturers that are producing other doorbells with this function. I'm wondering if there is a list of products that are compatible that I could check against? Or is there a default protocol that the device runs on that I need to look for?
Thanks in advance for any help or direction you could give.
August
Hi @Clinton74 you can check the list of compatible devices here: https://www.telus.com/en/smarthome-security/security-system-products/compatible-products
a month ago
Thank you, I appreciate it. 🙂 I see that there are no doorbell cameras listed; is thee anything mentioned elsewhere that would work with the system>
a month ago
No, that would be it at the moment.
