Onboard storage for camera
Siam12345paye
When I use onboard storage on my cameras do you my still use the clips when recording and does it use the sd card and save clips
A-B
Community Manager
Community Manager
Hey! What cameras are you using, and by onboard storage do you mean not in the cloud but actually with in the device itself?
2 REPLIES 2
A-B
Community Manager
Community Manager
JamesStewart
Organizer
Don't quote me on this at the moment as I don't remember exactly, but if I'm not mistaken, TELUS can enable it so you use the local (i.e. microSD) storage and can access those clips from the app.
Type a product name
