- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
01-03-2024 07:29 PM
I have an Alarm.com smart thermostat & an emergency low temperature sensor in my basement connected the Telus security system. However wondering if there's a way to set an alarm + notification to give an earlier low temperature warning (e.g a temperature setting ~5 degrees lower than the heating set point & approx. 5 degrees above the emergency low temp sensor) when the house is left empty e.g. during a winter vacation. This would provide an earlier notification of impending heating problem & sufficient time to correct before freezing.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
01-05-2024 04:01 PM
I'm not sure if this is entirely what you're looking for but does this help?
Log in to the TELUS SmartHome app on your mobile device.
- Look for the temperature settings or temperature thresholds section.
- Set the heating set point to your desired temperature for when the house is occupied.
- Look for the low temperature sensor settings or alerts section.
- Set the emergency low temperature sensor threshold to your desired temperature for triggering an emergency alert.
- Look for the temperature alerts or notifications section.
Set up a new temperature alert/notification with the following parameters:
- Temperature threshold: Set the threshold to a temperature approximately 5 degrees lower than the heating set point.
- Notification recipients: Choose the users who should receive the notification.
- Notification method: Select the preferred method of notification, such as push notification, email, or SMS.
- Schedule: Set the schedule for when the alert/notification should be active, such as during your winter vacation.
Save the settings.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Not the Solution
01-05-2024 04:01 PM
Save the settings.
