- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
11-09-2020 01:38 AM
I have a new fibre service installed in June and I can`t find any reference to setting a static IP in the hub. Setting up port forwarding was no issue, but my laptop changes IP everytime it reboots. Any hintsÉ
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2020 05:53 PM
I don't have that router so I can't verify but there should be an admin screen for managing DHCP reservations/static assignments. Ensure your laptop is set to use the hardware MAC as @NFtoBC already mentioned before making the reservation setting otherwise you'll be trying to hit a moving target.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2020 12:58 PM
Static IP is only available on business accounts.
If your laptop is being assigned a different IP by your router, that’s is a different issue. Some devices are requesting fresh IP from DHCP servers as a privacy protection. I know Apple has started this with some of there devices.
You should be able to assign IP by MAC address it the router, or check your laptop to see if there is a setting where it chooses to renew the IP lease, rather than request a fresh one.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2020 03:10 PM
Thanks for the explanation. I was more curious than anything else, since previous routers had static IP procedures built in. It`s really more of a nuisance than anything else. It only takes a moment to go into the settings and change the port forwarding info.
I appreciate your quick response.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2020 05:53 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2020 10:01 PM
Is this where I should be to assign a static IP?
Network > LAN > LAN DHCP This section helps to assign a fixed IP address to a local network device.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2020 10:15 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
11-09-2020 11:01 PM
Good. I guess time will tell.
