December
December
If you have a PC directly connected to any of the four LAN ports, try the following:
December
December
The modem has gigabit ports and it should automatically default to that. I don't know of any speed settings on the modem for those ports. It may be a problem with the modem itself, especially if there is no issue over MoCA. Get in touch with tech support and explain the situation and see if they may be able to send out a replacement.
