a month ago
a month ago
Depending on your needs and budget you may wish to look at Starlink. A friend of mine is on a rural property and recently got this and it's been a major improvement from xplornet and LTE which he's used in the past:
Starlink in Canada - Review of cost, speeds & coverage | Cansumer
a month ago
@Zulzrin Unfortunatly no one on here can tell you what Telus timelines are for fiber. High density population areas first. Rural areas will wait a long time. It is a costly thing install. Our town was one of the first to be done in BC.
a month ago
a month ago
