SunshineAndSnow
6 years agoNeighbour
Wireless Extenders plugged into LAN port?
I have my Telus modem in the garage in the basement. A LAN cable runs to the main floor and also to the bedroom upstairs (3 levels). I have one Wireless Extender on the 2nd floor, plugged int...
- 6 years ago
They will work happily, and better if both connected by Ethernet. If necessary, you can disconnect the more distant one from Ethernet, and it will act as a mesh connected device at half the speed it currently does.
6 years agoWhich wireless extender? There are a number of different models.
Also, which router do you have?
- SunshineAndSnow6 years agoNeighbour
It says Model DWS
White flat dish with a blue light.
- NFtoBC6 years ago
