RonAKA's avatar
RonAKA
Rockstar
6 years ago
Solved
  • xray's avatar
    6 years ago
    Is Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
