RonAKA
6 years agoRockstar
- 6 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
6 years agoHero
RonAKA wrote:Well, the relief by allowing the broadcast of the SSID was short lived. Just tired the iPhone Stocks app and it timed out and gave me a message saying I had no network connection. This is while the icon at the top of the screen says I am connected to a network, and I'm sure if I checked in the WiFi Settings it would show connected to the right network as well. The second try on the Stocks app after it timed out, worked almost instantly. I have no idea what is causing this, but it seems the iPhone thinks it is connected but it isn't.
It must be almost time for another release of iOS 13 with a faint hope they may fix this issue...
Does the T3200M show your iPhone as a connected device when this happens?
RonAKA
6 years agoRockstar
Yes, I recall that both the Router and the iPhone show it as connected, but when you use an app that needs Wi-Fi, it comes back saying they are not connected. Then when you try a second time it connects immediately.
- RonAKA6 years agoRockstar
I switched to a fixed IP for my iPhone. It worked for about 3 hours yesterday. It now does not work about 2.5 hours after signing in this morning. Not a solution.
What do you think about manually setting a fixed IP address assigned to the iPhone MAC address?
I have seen that theory about power saving being an issue when searching for a solution on the web. On a quick look it seems turning on the power saving is an option and does not happen automatically. Just downloaded iOS 13.3 and am praying there is a fix.
- xray6 years agoHero
So it sounds like there is an issue with the OS layer not reading the state of the WiFi connection properly from the hardware layer. I don't own any Apple products so I'm just guessing here but is there any power saving features on the iPhone that may be turning off WiFi and not turning it back on properly?
Related Content
- 3.5KViews8Comments
