RonAKA
6 years agoRockstar
- 6 years agoIs Smart Steering turned on? If so try turning it off. You will need to create a separate SSID for each WiFi band (2.4 GHz and 5 GHz) so keep the SSID for the band used by the most devices and create a new SSID for the other band.
6 years agoHero
RonAKA
6 years agoRockstar
I have dug a little deeper and determined that SmartSteering is enabled. My question now would be how I can go from essentially one merged 2.4 and 5 speed to two separate ones. I'm a little worried I might mess things up, and especially the TV...
