Rocky3
10 months agoGuardian
Volume Issues
I am watching a show, whether live TV, recorded or streaming. The sound volume goes up and down during the show. At times (TV sound 1-100) it will be just right at 10, other times it is 50.
This is...
10 months agoRocky3 Grimmt An update: our team is aware of the issue and we're working on a fix. When there's more info we can share, we will definitely let you know.
- KHR10 months ago
TELUS Team Member
Can you help us out with some details a bit to try and get to the bottom of it?
- can you confirm set-top box make/model (TELUSTV-21T or TELUSTV-24S, other)?
- is it across all channels?
- do you have your set-top box volume set to 15 (ask google assistant to 'set volume to max')?
- Are you using anything other than set-top box to tv and using TV speakers?
- Any sound settings you've changed on your TV?
- Grimmt10 months agoAmbassador
Here’s my info:
TELUSTV-21T
Yes
Interesting: I did this on one of my TVs and the volume instantly increased and I needed to reduce the TV volume. I’ll monitor if the problem continues.
Meanwhile: Is there a way to query what the current setting is before doing this? I would assume this would be important feedback. I have not done this on my other TV; so, I can provide info from my other TV that has the same issue.
No – I have the TELUSTV-21T directly connected via hdmi
Before the problem started? no
Since the problem started? yes – many changes in an unsuccessful attempt to fix the problem.Tony
And a question and answer, surprisingly missing from the questions - maybe the set top box reports this:
What make and model of TV do you have?
LG OLED CX
