Jerry3
2 years agoNeighbour
Upgraded to fibre and now Alexa will not connect to optik
Prior to the upgrade Alexa connected easily to optik. Now I have enabled skills disabled skills deleted items and repeat repeat and finally I've just given up. I have called for technical support but ...
JG3
I have tried this several times but I have never received the email you mention in step 5. I do however receive a text telling me Telus Home Assistant has been linked but that text does not provide any link. I had previously replied to your response but after completing a rather detailed description of the problem I hit the reply button and the received a notice that my reply was rejected because it was not linked a known ticket. Add that hour to the many hours I've already spent on the issue and you can understand why I am so frustrated and disappointed. Please send a tech to fix this problem.
A-B
Community Manager
2 years agoSorry about that. I'll reach out to our home assistant team to see if they have any insights. KHR and Optik-Kate is this anything you'd have any tips for?
- JG32 years agoNeighbourPerhaps it would be helpful to tell your technical people that my three wireless 4K set tops and the PVR all appear in mytelus, Telus connect and on the modem. They all show the network connection as ethernet. I have reset and rebooted all the devices and number of times and still the devices cannot be discovered.
- Optik-Kate2 years ago
TELUS Team Member
Hi, is your Alexa connected to the internet? If you ask for the weather does it respond? If it is connected, have you seen this page? It contains set up instructions and troubleshooting steps. Hope that helps! https://www.telus.com/en/support/article/telus-home-assistant-on-amazon-alexa?intcmp=tcom_amazonalexa_cta_ffh_connectyouramazonalexa&srcRef=20
If it's still unresolved, I do recommend reaching out to our support team and have them escalate you to the correct team. If you try the chat bot (smiley face on the bottom right), they are usually a bit faster when you request an agent!
