c0br3tii
4 years agoNeighbour
UISP UFiber loco GPON CPE compatibility with Telus Fibre
Hi, Is it possible to replace my current NOKIA ONT Fibre Modem with an UISP UFiber loco GPON CPE? https://ca.store.ui.com/ca/en/collections/operator-isp-infrastructure/products/ufiber-loco ...
- 4 years ago
c0br3tii Wrote: would it still work?
I would highly doubt it... First of all the Telus supplied Gpon modules are registered within the Telus database. There is no where to insert the module into the UISP UFiber loco. I'm not sure how you would convince Telus to utilize a untested/unknown MAC address in the UISP UFiber loco to get access to the network.
2 solutions that I can think of, leave the Nokia in the line in bridge mode, and use your own routing solution, or remove your Nokia device, plug the supplied GPon Module into a Ubiquiti Unifi device sync up to the 1.5Gbps service.
If you have 2.5Gbps service, you have very little choice but leave the supplied Telus device (Arcadyan NH20A - Nokia XS-250X-A) in the system in bridged mode, and output from the 10Gbps port is the only way the 2.5Gbps can be routed to your own equipment.
Cheers...
c0br3tii
I to have my own routing solution and wireless. that is not the issue...
I would like to stop using the NOKIA ONT and replace with the UISP UFiber loco GPON CPE main to use the POE capability it offers..
Understanding it would not be supported by Telus at all, would it still work? I read something about the need to be 2.5gbs compatible and also that perhaps it would need to be registered at telus end somehow...
DrPacman
4 years agoRockstar
Cheers...
