Wobblyfish
1 year agoFriendly Neighbour
TV Remote not pairing with LG TV
Hello, I'm running into an issue and support doesn't seem like they can help. I have an LG Oled TV and I'm unable to pair it with the remote that came with the optik tv box. When I try and ...
- 1 year ago
Thanks I figured it out, it was my sonos causing issues. I had to unplug it, pair it and then plug it back in and now it works.
Wobblyfish
Hey Telus Support,
I did & I also called in to Technical Support, but weren't able to help. It was frustrating because it took several hours to finally get an answer and alot of repeated steps.
The issue is the Telus TV Remote can only link to the TV by going through settings, which only tries 3 codes for LG TV. LG is known to have 18 Codes according to Telus's documentation.
It's frustrating because the Slimline Remotes have the functionality to manually enter TV codes. If you have any idea how I can get it to work it'll be apperciated.
- TELUS_Support1 year ago
Thanks for the response. I will add some codes here to try to help. Please us know which works: 017, 273, 266, 178, 059, 197
- Wobblyfish1 year agoFriendly Neighbour
Hey Telus Support,
How would I go about entering codes for the Telus TV Digital Box Remote? Settings doesn't give me an option to manually try codes.- TELUS_Support1 year ago
Try these steps:
1. Press and hold both the input and OK buttons on your remote for 3 seconds. The green LED should stay on.
2. Enter the first code using the number pad. The green LED will blink twice and then go off.
3. Test the mute or volume up/down button. If these work, you're done.
4. If they don't work, repeat steps 1-3 for subsequent codes.
Related Content
Pairing the RB21T remote for new Telus digital box with Samsung QN75Q80 TV
I have gone through the pairing process several times including with Telus support, and while the volume/mute sometimes works, the TV never powers down when I power off via the Telus remote. Instead,...Solved4.7KViews2Comments
